Hihat pedal-Alesis Strike Multipad
Drumer1228
Post by Drumer1228 »
Hello, I want to ask….I have an Alesis strike multipad through EZ Drummer3 software, but I can't control hihat through CC, only closed hihat on one pad and open on the other pad. I would like to use only one pad and through Pedal Yamaha HH65 or Roland FD9 control the hihat opening in EZdrummer. Is it possible with your device? And which one?Thx
Re: Hihat pedal-Alesis Strike Multipad
a MIDI Expression can handle the pedal, but not the pad. If you need one device to handle both, you'll need to get an eDRUMin.
