I'm using 4 moog ep-3 expression pedals with the Quattro. They are practically un-usable with this device. It is reading them in the plug-in and stand alone, but the sweep is all over the place. When I do a full sweep of the pedal, it jumps from 127-0 then 0-127 in one full motion. I'm using it with ableton and trying to use the pedals to control "midi-learn" functions with massive software synth. Hard to explain this, basically, I can get the pedal to sweep, and it is controlling the effect parameter, but is very chaotic and jumps from the extremes multiple times during one sweep motion. Also, some of the pedals do not work at all. Do I need to change the CC value? (It's set to 4) do I need to change the channel number for each individual pedal? I have been reading the Quattro manual, and haven't found any solutions to my problem there. The calibration function is useless. All this is on MacBook Pro Yosemite OS X. When I use my novation launch control midi controller to try to do this same exact thing, assigning parameters via midi learn to certain knobs, works just fine...
I have attempted to install the latest firmware. I'm 99% sure that the firmware update was successful, I have the opaque blue Quattro, so I see no light. I ran the script, and it opened up the teeny app and appeared to be successful.
The pedals and cables have been tested using other devices and work just fine. Any ideas would be appreciated. Just got this device yesterday and am pretty excited to be able to use it...thanks!
Expression Quattro can not calibrate
Re: Expression Quattro can not calibrate
Sounds like you need to flip the polarity switch on the pedals. I'll take a look at the calibration function as this was recently worked on and it's possible I missed a bug.
Thanks for the quick reply. I figured it out. Cable issue. Not exactly sure what, but when I switched the cables to the ones that came with the Moog pedals, it works perfect.Rob wrote:Sounds like you need to flip the polarity switch on the pedals. I'll take a look at the calibration function as this was recently worked on and it's possible I missed a bug.
Now I'm struggling to get the pedals to assign to individual parameters. All 4 are controlling the same parameter, every time I switch the midi learn to a different parameter, all 4 control said parameter...they are all assigned to different channels in the plug-in app (1-4) and when I do the midi learn with the novation launch control, that works perfectly. Any ideas here?
I'm guessing the plugin is in some kind of omni mode where it disregards the channel. Just change the CC's of each input to some unique number.
Success!! thanks for your help. Great product and great customer service!Rob wrote:I'm guessing the plugin is in some kind of omni mode where it disregards the channel. Just change the CC's of each input to some unique number.
