Quattro works fine with Mainstage 3?
rosetree
Post by rosetree »
Hello. Does the new Quattro port work fine with Mainstage 3?
I would appreciate it if anybody has actually used it with the software
for possible problems if there are any.
Thank you and I will be waiting for your input.
Re: Quattro works fine with Mainstage 3?
I just tested it out.
rosetree
Post by rosetree »
Hello Rob!
Thank you for testing it out and even making a video of it.
It is much appreciated and I am grateful for your help!
Now, Quattro can be purchased with no worries.
Once again, thank you so much!
Rosetree
