I have situation where the C-2 is not sending an Off Note...
All other notes above C-2 will send off note
All other channels C-2 will NOT send note off
Situation is the same whether on DAW/VST or Stand Alone
Very strange... only appears to be issue with C-2
I have double checked, via Midi-OX and Wireshark USB Cap, neither are seeing C-2 OFF note
I ensure there's no transformation turned on...
I have factory reset...
I downloaded Version 2.9.1.7 and installed, but when opening ME Panel, it still Shows 2.9.1.6 firmare, and does not prompt to update...
Any suggestions why C-2 Off note isnt working?
C -2 not sending Off Note
Re: C -2 not sending Off Note
Thanks for the report. I'll look into it today. You're using a sustain pedal to generate the note on/off?
I'm using Yamaha HH65 in Note Mode, so i can have note velocity
Thanks again. It's fixed for the next release.
ok great, thank for the update
Issue is still in firmware 2.3.1.16 (hit note c-2 doesn't send off note, all others notes do)
Spend an hour recabling, checking, switching pads, updating,...
Glad I found this post so I can stop troubleshooting
Not a biggie, just a note.
EDIT --> edrumin8 modules (not midi expression)
It's working fine in build 17.
