Sustain pedal for pitch bend
carburetor
Post by carburetor »
Is it possible to use a continuous sustain pedal (like the Yamaha FC3A) with a MIDI expression interface to control pitch bend? I would like to use one pedal for pitch down and a second pedal for pitch up. When not pressing either pedal, the pitch would be at zero, or unchanged.
Re: Sustain pedal for pitch bend
Sure. You would use the expression curve for that. One pedal would be setup like this:
And the other would be like this:
carburetor
That's great; thanks for the quick reply!
