Firmware Update Instructions
This thread is very old, and the firmware packages linked here are not compatible with the full size USB B devices. If you have a problem with a USB B device, please contact support.
While MIDI Expression Control includes an integrated firmware updater, users having issues can follow these instructions to manually update their firmware. The lastest firmware packages are linked below.
Firmware Packages
MIDI Expression 2 (micro-USB)
Imagehttp://www.audiofront.net/ME2_Firmware_OSX_2.6.0.1.zip
Imagehttp://www.audiofront.net/ME2_Firmware_PC_2.6.0.1.zip
MIDI Expression (mini-USB)
Imagehttp://www.audiofront.net/ME_Firmware_OSX_2.6.0.1.zip
Imagehttp://www.audiofront.net/ME_Firmware_PC_2.6.0.1.zip
MIDI Expression Quattro (micro-USB)
Imagehttp://www.audiofront.net/MEQ2_Firmware_OSX_2.6.0.1.zip
Imagehttp://www.audiofront.net/MEQ2_Firmware_PC_2.6.0.1.zip
MIDI Expression Quattro (mini-USB)
Imagehttp://www.audiofront.net/MEQ_Firmware_OSX_2.6.0.1.zip
Imagehttp://www.audiofront.net/MEQ_Firmware_PC_2.6.0.1.zip
MIDI Expression iO (micro-USB)
Imagehttp://www.audiofront.net/MEIO_Firmware_OSX_2.6.0.1.zip
Imagehttp://www.audiofront.net/MEIO_Firmware_PC_2.6.0.1.zip
Instructions
PC users can just follow the instructions included in the firmware installer.
OSX users should use the instructions below.
1) Extract all the files from the archive into a folder.
2) Close MIDI Expression Control if it's running.
3) Plug in the MIDI Expression.
4) Control-click and open the Teensy.app found in the 'tools' subfolder.
4) Control-click and run the UPDATE_FIRMWARE script.
5) Select the color you want to use and press RETURN.
The script opens the Teensy application and programs the chip. If successful, you should see the progress meter moving as the chip is being programmed.
Once complete, you can close it.
If you get an error saying that the "Teensy Application is damaged", follow the instructions in the link below.
http://www.mackungfu.org/dealing-with-d ... r-messages
Satri
Contact:
Re: Firmware Update Instructions
Post by Satri »
Thanks for providing these instructions.
The MacKungFu trick did not do it for me on the latest macOS, but the following did:
0. Complete the prerequisite steps first (such as quitting the control app)
1. Open a terminal
2. With a series of 'cd' commands, navigate to the 'tools' folder where the Teensy app is found
3. Type
Code: Select all
xattr -d -r com.apple.quarantine teensy.app/
4. Move up one level 'cd ..'
5 Run the script with
Code: Select all
/bin/sh UPDATE_FIRMWARE.command
Teensy will automatically open and will display a success message if it worked.
Hope this is useful! :-) -- Alex / Satri
Synth soloist & Moog official beta tester || Maintainer of Animoog.org || My music on animoog.org/satri || ROLI Seaboard RISE, Roland RD-300SX & Theremini
bennitzan@yahoo.com
Post by bennitzan@yahoo.com »
Teensy prompts me to "Press Button on Teensy to manually enter Programming Mode." First, I thought Teensy was a program, not a device. Second, what button? I've got a MIDI Expression.
Franko
bennitzan@yahoo.com
Okay, fixed. The program button is on the pc board inside. Use a knife or straight slot screw driver to grip the hex nut on the 1/4" input connector. Gently separate the case from the assembly (mine required additional cursing). Inside, under the tip of the connector, is a small button. Follow instructions as stated, then gently re-assemble unit. It's really quite easy.
Franko
HerbertCdMx
Post by HerbertCdMx »
Hello, good morning!
I have a "Red - Quattro" interface (micro USB) -purchased in 2018- really new, i don't know the firmware version, i'm running in OSX sierra 10.13.3 (17D47) and Win10, the problem was in win 10... It was working totally and perfectly in both Operative systems... everything very good in NativeInstruments and Pianoteq software... until...
I made the mistake of updating the firmware (from the updater in the "MidiExpressionSoftware"), and then: My Quattro was immediately fulminated, in the act, dead, because it isn't recognized anymore by the "MidiExpressionSoftware"(neither OSX neither Win), because when i connect it, and open the "MidiExpressionSoftware", it asking connect a MidiExpression Interface ("Black" screen)...so, i try get it back to life my unit, whit the "Script and Teensy" package in this post...
The instructions that recognized the "Update" script are:
Last login: Fri Mar 16 23:23:22 on ttys000
You have new mail.
iMac:~ HJH$ cd downloads
iMac:downloads HJH$ cd MEQ2_Firmware_OSX
iMac:MEQ2_Firmware_OSX HJH$ cd tools
iMac:tools HJH$ xattr -d -r com.apple.quarantine teensy.app/
iMac:tools HJH$ cd ..
iMac:MEQ2_Firmware_OSX HJH$ /bin/sh UPDATE_FIRMWARE.command
Current Path:
/Users/HJH/downloads/MEQ2_Firmware_OSX
--- MIDI Expression Quattro Firmware Update ---
What color of device do you want to update?
(r)ed
(b)lue
(g)reen
(y)ellow
(w)hite
blac(k)
Press the letter of your choice and [ENTER]: r
Opening Teensy Loader...
Teensy did not respond to a USB-based request to automatically reboot.
Please press the PROGRAM MODE BUTTON on your Teensy to upload your sketch.
BUT... as you can see in the text before, the Teensy software ask me that press the "Program Mode" push microswitch button, physically into the "Quattro" Interface (or at least i think, there it is... i'm not totally sure about that... somebody knows it?)...
So...
1.- ¿How can open it and push that switch, without harm the box interface plastic enclosure?
2.- ¿The waranty is lost if i open the interface?... So, the "Script-Teensy" update method isn't a permitted updating method when the midi expression unit doesn't respond to the "USB-based request for reboot and is mandatory to push the "ProgramModeButton"?
3.- Which update i have to use for my "Quattro" interface: The "Quatro update" or the "Quattro 2 Update"???
4.- Was it an error to have updated it fro the "MidiExpressionSoftware"?
5.- Should it be updated only with the "Scripts/ Teensy/ Push Program mode button" method?
6.- Or is ok update it from whatever both methods, and what happens is that my interface is defective because its turn blocked when i update it from the "MidiExpressionSoftware"?
Or: somebody can tell me how can bring to back life my red "Quattro" interface again please???
i tried already the "official" instructions by AudioFront, but doesn't work: The unit still remains "dead"... "sleep"... by the way, the "led flashing" at the start up when the box is connected, doesn't turn on anymore neither.
WHAT CAN I DO PLEASE?
THANKS A LOT !!!
Thank you for the detailed information. I can help you get your device back up and running. Please contact me directly, support(at)audiofront(dot)net
