I just tried to update firmware on a blue and yellow midi expression singles.
Both died in the attempt using the midi expression app.
No more light in the device when connection to USB, and they are not recognized with the midi app anymore.
When I try to get the old firmware back I just get the message "Please press the reset button on yout Teensy to upload your sketch. Auto-reboot only works if the Teensy is running a previous sketch."
Is there any way to reset the midi-expression device?
Need at least one of them tomorrow...so I really hope there is a solution.
cheers
**** update ****
after disassembly of the unit...pressing some sort of reset button...trying 25 times...the update finally worked. Strange....
At least I got one unit working now
![Smile :)](./images/smilies/icon_e_smile.gif)
