Hello:
2 questions:
I understand you can set min/max values in the CC mode with expression pedals. Can you set min/max values with switch pedals and pitchbend?
Would your converter work with a slide potentiometer? These seems like it could used to build a pitchbend ribbon controller. Perhaps the software could use a "snapback" option (e.g. snap to 64 upon release) and perhaps a "relative" option as well (i.e. start bending from point of contact).
Thanks.
Chris
Ribbon Controller
Re: Ribbon Controller
Sorry for the extremely late response.
Yes and No. The firmware would support that, but it's not currently implemented in the Control Application.Ctopher7 wrote:I understand you can set min/max values in the CC mode with expression pedals. Can you set min/max values with switch pedals and pitchbend?
I'll have to do some research and get back to you...I suspect it's doable.Ctopher7 wrote:Would your converter work with a slide potentiometer? These seems like it could used to build a pitchbend ribbon controller. Perhaps the software could use a "snapback" option (e.g. snap to 64 upon release) and perhaps a "relative" option as well (i.e. start bending from point of contact).
I would not think a slide pot would work well for pitch bend. I have a couple of sensor strips bought from SparkFun. These are position sensitive variable resistors. Easy to mount and can be covered by cloth, plastic film or whatever.
https://www.sparkfun.com/products/8681
Support for these and any other potmeter-like control units would be great.
The Yamaha CS80 and 60 had a great implementation of the ribbon controller. You could press anywhere, and that becme the starting - middle - position. For a deep downward bend press far right and slide to the left. And vice versa. Letting go of the strip snapped back to the middle position.
Best,
Blix
Best,
Blix
