Faster scan time? Latency advantages?
Fbeauvaisc@hotmail.com
Post by Fbeauvaisc@hotmail.com »
I've read in a few forums that most roland modules run around 3-4 ms (some even more), even before ever getting into the pc. Is it safe to assume that using DSP trigger with fast converters would beat those numbers? Can DSP trigger fonction at 32 samples buffer size? Could it have faster scan time than the relatively slow roland modules?
Thanks
-Frank
Re: Faster scan time? Latency advantages?
Certainly. If your input buffer is down to 32 buffers, then the audio would arrive in your computer faster than MIDI would.
Great! Can't wait to get back from the tour to try all this! Thanks again for the brushes updates! Looking forward to it!
