Hi-hat presets VH-11 & up
Fbeauvaisc@hotmail.com
Post by Fbeauvaisc@hotmail.com »
Is it easy to map and calibrate a VH-11 & up (VH-12, VH-13) hi-hat controler? Are there presets for hi-hats? Only a few modules fully supports those hi-hats. If DSP trigger works well with those, it would be another great benifit over most modules.
Thanks!
-Frank
Re: Hi-hat presets VH-11 & up
There currently in no support for hihats as there's no way to get MIDI CC data into DSPT. Version 1.6 which is in testing has partial support for hihat controllers when they are plugged into a MIDI Keyboard. I've also built some prototype hardware to support hihat controllers, but it remains to be seen if I'll be able to produce it well and cheaply enough.
Rob.
Keep up the great work. Good luck!
