Ghost notes
mangiedog
Ghost notes
Post by mangiedog »
I am demoing DSP Trigger in Ableton and Logic. I am using a Roland mesh, into Duet 2.
The audio signal is fine, but in the DSP plugin single hits are creating multiple midi notes on the decay of the audio, have tried calibrating multiple times but can't get it to stop showing and then triggering decaying midi notes, what am I doing wrong?
Cheers,
Steve.
Re: Ghost notes
It would seem that either the threshold or the hit decay is being calibrated a little too aggressively. Try backing off the these controls a bit so that the curve in the input section doesn't hug the transient so closely.
