Hello,
I am trying to test DSP Trigger 1.6.0.9 but can't get it to work.
I tried with Nuendo 5, Reaper, VST-Host, 32 bit and 64 bit.
When I try to open the Editor GUI it appears empty.
Just some black empty panels on the top, rest black.
VST-Host loads the plugin -> no error, when I try to open the GUI,
the plugin throws an exception (not visible, I see it in the log).
Here you see the editor and the log:
System: Windows 7 ultimate 64bit,
Komplete Audio USB with actual ASIO drivers
DSP Trigger free works.
Do you have any idea?
Exception loading Editor
Re: Exception loading Editor
.... I'll take a look tonight.
So I basically recompiled with my updated graphics libraries--there's a good chance this will take care of the issue. Give this a shot and let me know how it goes.
http://www.audiofront.net/DSP_TRIGGER_PC.1.6.0.10.zip
Wow, that's what I call service! I'll give it a try and send you feedback? Thank you a lot Rob.
Hello Rob,
unfortunately it didn't work.
The same exception as in my recent post.
Best regards,
Andreas
Best regards,
Andreas
I just noticed that your screenshot with VSTHost is loading the 32bit version. Perhaps you are experiencing bit bridge issues.
I guess I should mention that the 64bit version of the plugin is likely stored in.
C:\Program Files (x86)\DSP Trigger\dspTrigger64.dll
Hello Rob,
sorry for my late reply.
I tried both versions, of course with the corresponding Hosts (Reaper, Nuendo, VST-Host).
Unfortunately the same error.
One remark to your last version: After the exception the log shows some more information
about some parameters, so I guess the code continues after the exception.
I'll try to send you a new screenshot.
Best regards,
Andreas
Best regards,
Andreas
