Roland PD-8
eriksan
Roland PD-8
Post by eriksan »
Hi, does DSP Trigger work with a non-mesh trigger such as Roland PD-8? I intend to mostly use it as a snare.
Re: Roland PD-8
It should. Assuming you have the pad already, you can try it out without purchasing.
eriksan
Re: Roland PD-8
Post by eriksan »
Thanks, I haven’t ordered it yet. Does that apply to positional sensing too, or does positional sensing only work with mesh pads?
Re: Roland PD-8
Positional sensing only works with mesh pads.
eriksan
Re: Roland PD-8
Post by eriksan »
Thanks, and I assume the mesh pad has to be built with positional sensing in mind, in order for it to work with positional sensing in DSP Trigger? I saw that, for example, PRX-8 does not have positional sensing.
