Compatible with Apple M1?
johan_rohan
Post by johan_rohan »
Hi there, I downloaded and installed, but can't see the plugin available in my DAW. I'm guessing that's because it is not supported by M1/Silicone Macs? If this is true, is there a plan to make this plugin compatible? It looks perfect, exactly what I was looking for, so was so happy to find it, but disappointed I'm not able to use just yet....
Thanks,
Re: Compatible with Apple M1?
For AUv2 plugins on modern macs, you typically need to reboot before you'll see the plugin.
johan_rohan
Excellent, that did the trick! Thank you
