thank you
I do not know if it is connected properly, my setup is correct?
I would like to turn the drums with DSP technology
And also need to connect the hi-hat cymbals and vh11 my TD9,
I'm sending you straight to VST MIDI signal, has another maneria to make it work?
What then would be the correct way, help me friend'm still faulty and cuts.
DSP Trigger FAULTS AND CULTS
Re: DSP Trigger FAULTS AND CULTS
I see you have two VSTi, but only one MIDI track. You should have two MIDI tracks and one VSTi
If that doesn't help, can you please describe "faulty and cuts". Can your send me a recording?
