Roland SPD30 Compatibility ED10
KnipeDrums
Post by KnipeDrums »
Is the Edrumin 10 able to expand the inputs of a Roland SPD30? Love the interface in ios, Thank You in advance, TK
Re: Roland SPD30 Compatibility ED10
Definitely. How do you want to use them together?
KnipeDrums
I would like to expand the amount of inputs and use the SPD30 as the module to trigger internal sounds with the pads connected through the EDrumin10. Right now I only have the 4 inputs on the back of the unit. Adding the Edrumin 10 would allow me to make a nice little compact traveling kit. Thank You again, Tom
Sorry for taking so long to reply.
I suspect you can just plug the SPD30 into the eDRUMin USB host port, but you'll need to check with the user manual to make sure you can trigger sounds on the unit with USB MIDI. If that doesn't work, you can always use standard MIDI cables to get the job done.
