I've done several firmware updates in the past and usually very careful but for some reason, today I updated the firmware while plugged into a usb hub and seem to have bricked one of my edrumin (4)
I tried to plug it in separately on both Mac and PC but it's no longer seen by the controller program or computer.
Is there a way to manually reboot or factory reset?
Update to 1.6.2.6 with hub...fail
Re: Update to 1.6.2.6 with hub...fail
Yes, you can recover the device. Please contact me via Technical support so I can get all the information I need to help you.
https://www.audiofront.net/contactSupport.php
Thank you, Rob for the support.
Was able to reset and program the unit.
