Two zone snare piezo rim
Re: Two zone snare piezo rim
For the crash that's triggering seemingly randomly, you need to increase the thresh control. It's too low and so it's triggering on random noise.
For the link control, here's the section from the manual describing how it works.
www.audiofront.net/manualUpdate.pdf
TheJay wrote:
MWJT42 wrote:
TheJay wrote:I reset all the modules and there snare and rim are working. Hi hat is killing me though. Everything is an open hi hat sound. How do I reset any changes in SD3 back to original settings for the add-ons?
Check your 'link' between pedal and pad in eDRUMin.
In the new release I see "link" in pedal settings but don't understand how to link it. Pressing the button seems to do nothing.
Click link, then click your HH pad. The icon will change to a Blue HH, so you know it's done.
TheJay
Post by TheJay »
Thanks, that changed image to hi hat instead of cymbal.
I thought I had it sussed until I tried to enable three zone. Now bell is dominant.
Same with three zone ride.
When you enable Bell Sense (three-zone cymbal) make sure you select one of the presets underneath the rotary control and fiddle with the knob values to adjust the bell sensitivity.
monospace wrote:When you enable Bell Sense (three-zone cymbal) make sure you select one of the presets underneath the rotary control and fiddle with the knob values to adjust the bell sensitivity.
Related: it’s my understanding that these presets are different algorithms, and I’ve found that selecting one based on the model name of cymbal you have doesn’t necessarily yield the best results. Maybe they should be labeled something like “low/medium/high sensitivity”?
TheJay
Post by TheJay »
Thanks Mono, perhaps that would be a better idea having sensitivity names. These are custom cymbals wired like CY15.
How come calibration doesn't adjust those types of settings? I did play with the the details als and didn't see any difference?
Calibration only adjusts the settings Gain, Thresh, Scan, Hold, and Decay. On drums it also adjust X-Stick and Rimshot, and on cymbals Edge and Bell. All other settings need to be manually enabled and adjusted.
TheJay wrote:Thanks Mono, perhaps that would be a better idea having sensitivity names. These are custom cymbals wired like CY15.
You have diamond low volume cymbals, wired as roland cy-15 but not recognized by the edrumin as such (3zones), you will have to wait until Dave comes out with a possible solution or until Rob takes a look at these cymbals.
TheJay
Post by TheJay »
I don't understand what difference it makes. What's the problem with having custom cymbals so long as they are wired correctly?
TheJay
Post by TheJay »
Dave did extensive testing using a Roland TD17 module so it should work well with eDRUMin.
