Good luck. I’m not kidding when I say it’s very elusive. I could play for hours and only encounter it once or twice.
If it happened more often, or was easy to reproduce I would have reported it sooner.
Triggering bug on ED4 connected to ED10?
Re: Triggering bug on ED4 connected to ED10
Re: Triggering bug on ED4 connected to ED10?
A couple of weeks later and I think I've nailed this down to the fact that the ED4 is more "sensitive" than the ED10. What appears to happening is that this weird artifact is caused by random voltage spikes. I like having my Thresh settings really low, around 0.7 or 0.8, which is fine on the ED10, but is clearly too low on the ED4. Bumping it up to 1 or 1.2 eliminates this "bug."
I've mentioned this in the "Presets" thread too, but if there's a way to unify those settings between devices, that would eliminate some of the confusion for those of us who own both.
I had my snare plugged to the edrum10, resetting the input sets the gain at 5, I swapped it and plugged it to the edrumin 4 and gain was set at 2.5 and noticed better triggering response and better positional sensing, so yeah, there’s definitely some differences between both devices in terms if triggering so you’d have to swap inputs and check the response with each device
