Hello to everyone.
First of all, congratulations on the entire eDRUMin initiative!
I am writing to you with a question because there are a lot of posts and it's hard for me to find answers
I am the owner of the ATV EXS 3 and i really dislike the limitations of the xD3 module ( xD xD xD)
I really like the Addictive Drums 2 that I use, but I have a feeling that the xD3 module limits the hardware's capabilities too much.
Are there any limitations or problems when using eDRUMin with exs-3 hardware?
For now, I only realizes that there will be no Positional Sense with a snare drum as there is no centrally placed sonsor.
Crashes in AD2 are only one zone
But what you know more ?
Won't smaller sizes disturb other functions?
Exs 3 set which is equipment smaller than those from the aDrums series
Three zone for cymbals
12" optical Hihat
14" ride
And 3 cones 10" dual zone pads
Regards, Jack
ATV other Stuff
Re: ATV other Stuff
Hello bro.
I'm using same you.
Not problem.
Cymbals(chokes) are works fine, split toms are too.
Go and get freedom from pads limit!
I'm using same you.
Not problem.
