I have to ask again:
I messed around with trim pots and I also stuck another piezo right on the outer shell,mprinz wrote:I am quite curious here ...
I have four models of pads,
the cheap Millenium 10" plastic, the Jobeky 14", the DIY 14" Snare and the 14" ddt MS 140, and the ATV 13" Snare pad.
And - really - only with the Millenium thing .. I got no false triggers with regards to x-stick or rim shot.
Those pads seemed to be well designed.
Rob, do you think that two potentiometers would solve most of these issues?
Apart from construction defects.
and that was just "moving" white marker more to the left side, or to the right, when changing the ration of head/rim input.
My problem "was" that I got X-stick trigger if I did subtle strokes on the edge or also in the center.
Now I raised the threshold from 0.6 to 0.9 and those annoying sounds are gone... but is that the way to go or did I miss anything?
And sure, the subtle, barely touching buzz roll hits are not detected...
But I guess that's the price when switching from a 12" to a 14"
pad?
